View Crop Boundaries
    I'm trying to update my graph to turn off view crop boundaries and have it working except for one part - I can't get the filter to keep interior elevations on while turning off all of the other elevations. Until recently it worked fine so the issue seems to have something to do with either a Dynamo update or a package update (Rhythym or Archi-Labs most likely.)
    chad
    What does the error say?
    John Pierson
    Creator of Rhythm, Monocle, Bang! and Lots of Other Okay Stuff.
    Twitter - @60secondrevit | Email - [email protected] | Work - parallaxteam.com | Blog - designtechunraveled.com | 🔗- bio.link/johnpierson
      Dereferencing a non-pointer. Super helpful right?
      chad
        I don't see any custom nodes in this script. And without knowing your Revit properties I'm not sure if your view type or parameter names contain correct values?
        edit. What happens if you use 'all elements of type' node instead of 'view.getbytype'
          I think you may be feeding the wrong thing into your "Filter.ByBooleanMask", the output should be an element with an ID and currently it looks like a string.
          John Pierson
            Our Dynamo guru creates it one for us some time ago.
Name:	2017-06-30 09_14_00-Dynamo.png
              edit:
              got it working. took some re-configuring but the path from the view to the filter needed adjusting.
              Thanks :beer:
              chad
