Stair: Runs: Extend Below Riser Base not working
yes this is one of those dumb revit things, it asks for an offset BELOW and so we assume that the value is already negative but the wording is poorly done in the parameter and its the same as an offset for anything else you need to enter the negative value as Elton suggested.
You're not alone here, I also scratched my head for a while trying to work out why my stair wasnt behaving a while back.
Are you kidding me? Well, no you are not 'cause I can see that you are right!
So how can it be that in some files you enter a positive number but in others you enter the reciprocal negative? I am happy to do it if it works, but that is odd.
Thanks very much.Last edited by anthonyB; June 28, 2017, 10:35 PM.
I imagine this has come up a bunch of times, but after some diligent searching, I'm still at a loss...
Even though the stair is set to go...July 30, 2014, 07:29 PM -
On this stair we want the nosing profile of the tread to overhang 1" over the riser. We are using a simple nosing profile and it works perfectly...January 31, 2017, 08:25 PM
I am trying to draw our helical stair in Revit, the top and bottom riser overlap which is causing problems when drawing the stair in sketch. Basically...January 16, 2017, 10:48 AM
Guys,
For our construction process we use precast stairs. In this particular case we are not only creating the precast 'main stair flight',...April 18, 2013, 12:57 AM -
I'm trying to create a stair that has a vertical of 2'-10 1/2". By my calculations, that's 34.5", and with a max Riser of 7", should give...August 29, 2012, 09:53 PM
