Hide floor finish from certain views
    I have created a finish plan that shows patterns to indicate certain floor finishes with a Key. This information is under "identity data" in the properties when the room is selected. For some reason, the finish is showing on the Egress plan when I just want it to show on the finish plan. Is there a category under view properties where I can hide it?
    How are the pattern's being applied? Do you have a filter applying the patterns based on the room data? If so, I'd make sure your egress plan isn't using the same template.
    We model finish floor's separately, and turn them off with a filter.
    Julie Kidder
    Architect + BIM Director
      We just select the room, and under the properties toolbar --> identity data ---> floor finish. From there, we fill in the fields. Other data includes, Workset, number, name, image, comments, occupancy, department, base finish, ceiling finish, wall finish, etc.
        That data alone won't provide a pattern, it's a filter, an element override or a color scheme.
        Julie Kidder
