Copying to Design Options
    I am creating several design options for a space plan. Can I copy elements from the main model to an option?
    You should create the options you need, then move them to a set (Manage > Design Options > Add to Set). You can copy/paste, but since it has to be removed from the main model move to set is better. Copy/paste si the only wya to remove something from an option and put it back in the main model.
    Julie Kidder
    Architect + BIM Director
