I'm having problems with space naming using 2017 version. Not all spaces were extracted from Archi's model. Some appeared as "Unoccupied" while some wasn't even enclosed. Do I need to manually create the space using "Space Separator" or there is still other way out?
MEP Space Naming
Lots of times the architects don't fully define and bound their Rooms, and they don't understand that our Spaces depend on their Rooms being properly enclosed. This is especially true if it's a tenant renovation type job in which they're using a CAD import for the building core and shell.
I'd give your architect a call and explain (in general terms) that you need him to enclose his Rooms properly. Tell him that these Spaces are connecting to your load calc software and photometric software and that you need the rooms to be complete in order for it to work. Even if that's not entirely accurate, it will get the point across to him to fix it.
If you're planning to do a gbXML export to a load calc sofware, you should be using Space Separators to carve up the larger spaces into perimeter and exterior zones. Some people don't use Spaces at all, and prefer to tag the Rooms through the Architectural Link, but you can actually do some awesome things with them.Last edited by Necro99; June 26, 2017, 01:56 PM.
Hi everyone i just saw a video from Cadclip CADclip - REVIT MEP 2008 - HVAC DEMO - YouTube
which show when you link architectural you can acquire...-
Channel: MEP - General
July 4, 2012, 11:29 AM -
I'm not too familiar with spaces but i've placed them on linked architects model anway for a bit of practice. Now that I've done them, I don't actually...
June 26, 2013, 10:11 AM -
I am looking for a way to easily remove all the spaces and rooms that have been created within my model. From originally creating them, my project has...November 10, 2011, 08:28 PM
How does the Space Naming Utility handle changes after the initial run?
The problem I'm having is that after we've done the initial creation of...-
March 8, 2017, 02:00 PM -
First, just want to say, I'm new to Revit (been using the past few weeks) and new to the forum.
My firm is (for now) using...-
April 5, 2013, 07:31 PM -
