Hi All, new here and to Revit, learning as I make my first project using 'Residential Design' by Daniel Stine to 'walk' me through it. Problem I have is that my 1st floor looks great, all wall details joined okay - everything cleaned up as I like. Then I go to start the 2nd floor and the wall details are just very basic outlines of a wall - not what i need. None of the core, sheathing, gypsum etc are visible in this view. I understand from checking forums etc that it may be the wall height about the floor plan level is only 700mm (the roof will be added to these walls) and when I increase the height of the walls temporarily the detail shows, so I guess that is the problem. But my walls must be this height - how do I get around this? If I change the view range on this floor to have the cut plane lower than the 700mm it still doesn't show detail. If I add the roof and connect it maybe it then shows detail but I would like to check my walls all are correct before I move on to the roof otherwise I might overlook something.
Plus maybe adding the roof makes no difference and I have to go back and remake something, which I don't want to do. Any ideas? Obviously it's a big problem because I can't see how any walls join up and I'd like to do that before I move on.
Any help would be great.
