Revit Local file contains the wrong path
    I am using Revit 2015 and the project resides on Revit Server 2015. I went to create a new local file and am getting a message stating the location for the local is an incorrect path and it will not open? Any ideas what is going on?
    hello i have gotten the same error. has anyone provided a solution to you? if so please repost because i cant see the response solutions to your post.
      For some reason, revit doesn't like long file names. Shorten the name of your revit file and it should solve the issue. *no idea why this happens*
        That actually sounds like a folder size issue. There may be too much data in the folder and Revit can't create the new local there. I've run into situations in the past where a fairly low maximum size has been imposed on folders on the C:\ drive. Check that too...
          Have everyone close out and the last one that sync'd should create a new central file.
          Make sure everyone is on the same build as well.
          Bettisworth North
