Constraining nested family to angle parameter
  • theoryshaw
    Bingo!
    "pick horizontal plane of the ref line"... That's some trippy higher dimension thinking.
    Thanks Much!
  • PijPiwo
    Make your plate family work plane based and uncheck always vertical -> load it to the parent family -> override -> select plate -> edit work plane -> choose pick a plane option -> pick horizontal plane of the ref line.
    EDIT: file enclosed
  • Andrew K
    Is there a reason you're using structural components in the family? What are you trying to achieve?
    I've never enjoyed nesting structural things into other families, as structural components tend to have their own set of rules.
  • theoryshaw
    started a topic Constraining nested family to angle parameter
    I know there's a number of forum posts addressing this, but after reading and trying to apply the solutions, I still cannot constrain this nested family (in the attached file) to an angle parameter.
    Any clues?
