Here is another brilliant and super succinct solution provided by Fair59, answering the Revit API discussion forum thread on how to get cutting void instances in the floor using the HostObject FindInserts method Question: I have a floor on which a family instance is inserted on the face of the floor (the instance host is also the floor). I checked in the family the "Cut with Void When Loaded" parameter, so that the void is created in the floor. Now, I want to retrieve all the instances that create voids in the floor...
