Drawing sheet/table/Scale-adding a parameter
    Hi there,
    I am trying to update a drawing sheet/table/Drawing Scale adding a new parameters (address,drawing title,scale etc.) .
    When I open the sheet in family .rfa I can see an added parameter.When I load the drawing sheet into the project,my added parameters(labels) are invisible.When I highlight the sheet, there are a question marks.
    What Am I doing wrong?
    Thanks for your help.
    Regards
    Pete
    You need to fill in the labels with parameters with some project information. If left blank they will display the ?
      Hi peterweaver, If those are OOTB parameters you need to go to the Manage tab and once then you must seek for the parameters you need to fill and proceed to fill with the required information as @elton williams already said on top, If those are shared parameters created by you, then you need to "link" those parameters into your project, you must go to Project Parameters and once then you need to hit on the Add button, then you must seek for you shared parameters .txt file and look for the desired parameter, be sure to choose the right category on the list, regards
      E.A Poe
