They say don't compare Revit to AutoCAD, well, this time I have to. I don't see it anywhere in Revit, but AutoCAD has an option to snap to a drawing grid. As I am dimensioning these 1/4" plans and I am thinking it would have been a big time saver to set the project up with snaps to at least 1/4" increments when placing walls. Lots of 1/256" - 1/16" dimensions. Am I just missing this?
Snap to Drawing Grid
Originally posted by dtp81390 View PostThis does not exist in Revit. use your temporary dimensions to enter in the correct increment.Bettisworth North
Originally posted by dtp81390 View PostThis does not exist in Revit. use your temporary dimensions to enter in the correct increment.Greg McDowell Jr
about.me/GMcDowellJr
Originally posted by GMcDowellJr View PostSure it does! Set the Work Plane, Show the Work Plane, change its Spacing as desired, move it where you need it, and be aware that you can still go between the grid points if you want. I've never seen anyone go down as low as 1/4" but that doesn't mean you can't (although I don't think you'll enjoy that experience).Bettisworth North
Very aware of what AutoCAD has and doesn't have... or at least I was as of some 15 years ago! LOLGreg McDowell Jr
Originally posted by Charles Karl View PostThanks, I am aware of the driving the elements with the dimensions which is great if every end user uses this method. What I speak of would force a wall to snap to a given fractional distance from another if an end users chooses not to type in hard dimensions.Jeff Hanson
Sr. Subject Matter Expert
Is there a way to set the precision of a model? for example, I don't want to be able to draw an object that is, lets say 5' 6/128" I want it to "snap"...September 25, 2017, 09:41 PM
So I have an idea for a Revit add-in, and I would love to get some feedback on whether its even possible to build, how difficult it would be to build,...
Channel: Third party Add-Ins, API and R&D
June 13, 2011, 05:30 PM -
Hi This is Ashwini. I am having problems dimensioning my views. Dimensions dont snap to grid lines, why is this so? The dimensions dont snap to perpendicular...March 15, 2013, 01:20 AM
I am trying to create a house based on a hexagonal grid i.e. lots of 30 degree angles.
In plan it’s quite a complicated building plan situated...September 9, 2019, 09:11 PM -
How can you set up to show level head automatic to the right or left when you create new view. Seem like when you create new view some on right...January 18, 2019, 02:39 PM
