xls in revit
    xls in revit
    hello
    i'm working on a HVAC project and i need to insert an XLS tab in revit
    I know it's very bad but i pent hours and hours (and nights and nights) to creat my prject and i can not tag as i would like to do it my reservation.
    the only thng readable on the tag of the reservation is the number of the reservation. i haven't any more time to get a better result, i just neeed to ba able to send a plan to your furnisher to make all the holes for the process
    i could be able to indicate on XLS the dimensions and the elevation of the reservations but i need first to import a XLS file in REVIT... in worse case i could insert a picture of the tab on XLS but i know it's really and (and i'm feelng to regress lower than ACAD)
    need help please i'm tired and i need to sleep
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    I find that printing to PDF and then converting to an image (150 dpi should be enough) gives the most legible results. Good luck.
    Chris Ellersick
      Hi philsogood, to do this you should create a dwg with yous XLS file imported on it , then you must link the dwg into Revit "I suggest to use link cad option" that way you'll be able to show and print your Excel file and refresh it if needed, hope this helps, regards
      E.A Poe
        very good idea Andres!!!
        i'll use a legend to insert my DWG
        Many thanks!
        Phil
        PS : why do you speak in English, i'm French as you are!!
        Revit 2019
          Hi philsogood, I'm glad you find useful my response is not new actually :blah:, there are a lot of threads that talks about this.
          Je ne suis pas vraiment Français non plus :laugh:, mais J'habite en France depuis quelques années donc voila, Je voulais t’écrire en français au début mais J'ai cru que peut être pour trouver une solution commun pour ta question il fallait mieux poursuivre le post en Anglais, salut et n’hésitez pas a m’écrire si t-as des questions spécifiques en Français!!, a plus
          P.S: N'oubliez pas liker mon post si tu las trouve utile! :hide:
          E.A Poe
