Guys,
I'm currently working on a water supply system. In the current situation I am tagging hot/cold water pipes and they are using the same pipe type but a different system. They will also have a different annotation in terms of color and text.
I have created two separate annotation families but I need to change them manually when I tag a different pipe. Is there a possibility to make this automatic? Can you assign a specific annotation family for a specific system?
