Pipe-in-pipe, containment pipe, double-wall pipe ?
    Hey guys, first post here!
    I need help finding double wall pipe and was wondering if anyone can point me in the right direction. From what I understand, Revit does not have a double wall piping tool (is there an add-in that might be able to do this). I have read a lot of people are placing their pipe in the model and then just adding insulation to simulate the double wall pipe. I am hoping to actually be able to model it correctly as a double wall piping system.
    Thanks for the help!!
    Gerry
    If I absolutely HAD to model it as pipe in pipe due to pre-fab or BOM needs, then yes, model both pipes. If it is just for base design/coord, then I would go with the insulation route.
    This is where a savvy Dynamo user would write a tool that would effectively double up your pipe system in place with the new larger size for the containment...
    Thomas N Fuller II
    LinkedIn
      I would suggest making a new Pipe Type (And Fittings) that has outside diameters consistent with the outer pipe for the inner pipe nominal diameters.
      That way you can model/change it easily without messing around with double pipes or insulation, and still use it in calculations.
      No one is ever going to see the inner pipe detail..
      • Pipe Insulation
        Is there a way to add insulation to only part of a pipe rather than the whole pipe?
        October 26, 2012, 01:22 PM
      • hide part of a pipe
        hello
        i'd like to hide a part of a pipe (the part which is in the red rectangle) because i'd like to see what is beyond the pipe
        in this example...
        January 7, 2019, 12:51 PM
      • Spud Takeoff
        I am trying to create a pipe branch that adjusts the takeoff length based on the pipe it is connecting to. So far I can adjust...
        January 19, 2016, 03:35 AM
      • Underfloor Heating Pipe Layout Add-On
        Hi... Is there Underfloor Heating Pipe Layout Add-On for Revit that you can model the layout automatically? Thanks in advance...
        March 21, 2016, 02:37 PM
      • Flanges for welded pipe
        Pro tip: If you are modeling welded pipe fittings, and need flanges to connect to valves and equipment, change your flange families to "pipe accessories"....
        August 19, 2021, 01:54 PM
