I only found one post involving Eccentric Pipe Reducer and it didn't answer my question. Is there a way to have the Eccentric Reducer default to Flat on Top when drawing pipe? I've tried playing with the Pipe Justification settings but this did nothing. Seems my Eccentrics are defaulting to Flat on Bottom but I'd like to change this so I don't have to take the time to Rotate every reducer which are quite a few on this 17 story Hotel. TIA.
Eccentric Pipe Reducer - Revit 2017
I find justify is generally too buggy to rely on, it often seems to flip the top/bottom/left/right directions for ducts. So I found a nice method when modelling eccentric ducts that also works for pipes;
1) make the small and large pipe/duct
2) use Align to align the edges you want to be the same (Or even 2 edges for rectangular ducts)
3) Split one of the duct/pipes near the end, this places a Union.
4) delete the small end piece of duct pipe after the union, so that the union has one open side facing the other aligned pipe.
5) select the union and use "Connect Into". This should create the connecting pipe and make an eccentric union without moving the two pipes.
It is neccessary to create the Union using Split because Connect Into is only available for fittings and not pipes (Why autodesk? Why?) so this also works from a T, bend or other family.
Note this only works with transitions that have the "Offset Height" and "Offset Width" parameters, such as the M_Transition-Generic one in the default revit content.
Attached Files"One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by josephpeel View PostI find justify is generally too buggy to rely on, it often seems to flip the top/bottom/left/right directions for ducts. So I found a nice method when modelling eccentric ducts that also works for pipes;
.....John Karben | IMEG Corp.
Yes, but like most things in revit it sometimes works and sometimes doesnt, the Connect Into option seems to solve some situations when dragging fails.
Wont work for pipes, it just tries to make a centred transition and slope the pipe down."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
how exactly do u control how flex pipe is modeled? u can not draw flex pipe in 3d view.
Channel: MEP - General
May 6, 2013, 07:48 PM -
So if I'm trying to make auto-sizing valves:
- do they only automatically adjust when placing them?
- Or can they auto-adjust all
Channel: MEP - Family Creation
September 4, 2015, 02:54 PM -
Hello,
I´m really confused here with a pipe template that I have received and not sure if I´m the idiot or those families have something...-
February 17, 2016, 08:09 PM -
hello
i'd like to hide a part of a pipe (the part which is in the red rectangle) because i'd like to see what is beyond the pipe
in this example...-
January 7, 2019, 12:51 PM -
Hello.
I'm making my own pipes fitting, but i'm having problem with my reducer.
When I deduce the pipe ø104 to ø79, for example,...-
October 14, 2016, 07:10 PM -
