Cable Tray Noise Barriers
    I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design. It would also be needed for an accurate Materials List.
    Could you elaborate a little on this item? Essentially, what is a cable tray noise barrier...?
    Thomas N Fuller II
    LinkedIn
      A barrier strip in installed in raceways and cable trays to separate high voltage cables from low voltage and signal wires so the noise doesn't interfere with the signals.
        I understand clearly now. But unfortunately I don't have the answer you want.
        Thomas N Fuller II
        LinkedIn
          If it is IN the cable tray it wont be possible to model it easily (And why would you want to?) but you could easily add a parameter to your cable trays for Noise Barrier (Yes no tick box) or Number of Noise Barriers (Integer). Then in a schedule do Tray Length x Barriers to get the quantities.
          Loading...
