Building Coder: Aligning a Slightly Off-Axis Grid
    Here is a follow-up on the recent discussion on how to modify a grid curve end point using Grid.SetCurveInView. In the Revit API discussion forum thread on off-axis grids causing warnings in Revit, an attempt to use the same approach fails. Instead, Fair59 presents a solution using RotateElement to align an almost horizontal or almost vertical grid that is slightly off-axis...
