Hi everyone, I am very new to Revit. I would like to create a family called 'meeting room' which is a 2D drawing of a meeting room which will be placed on a floorplate to test an office layout. I need this family to adaptable in terms of changing the length and width of the room, but the changes should not affect the dimensions of the door, chair or table.
With this I would like to ask:
1. Which Family template should I select?
(I was contemplating between Model Generic Adaptive, Model Generic Floor, and Model Generic Faces, but I don't know the difference)
2. What do I select to make the length and width a parameter?
(I've tried putting an aligned dimension between two walls but when I imported the family in a project file, changing the dimension does nothing. I tried again with points at the corners, but it did not work)
3. How can I ensure the wall thickness remains the same?
4. How can I ensure the furniture and doors will not change?
Thank you very much! I appreciate any help or references to other tutorials.
