Cannot apply dependent view
    I am trying to apply dependent views to a stand alone view but only two views are listed when i select the apply dependent view option. I have many other views that the dependents could be applied to. But none of them show up on the list and i dont know why.
    Hi Blaze,
    Bit of a late reply, but hopefully it will help others searching.
    Both parent views need to have the same scale: The view you are copying the dependent views TO needs to be the same as the original parent view you are copying FROM.
    You can workaround this by temporarily changing the views you are applying the dependent views TO to the same as the original parent view temporarily, then apply the dependent views, then change the view scale of the new views - easy.
    Hope that helps.
