hello
i should definetly do not working with the good tips
I used to work on ACAD and i often copied items from one pipe/duct to another.... i'm doing the same on revit (because i need to copy the valve AND the flanges) but when i do this the items stay on the system type from where i take them.... and it's very hard to change it to the right system...
most of the time i need to delete flanges, then insert valve (for example) on my pipe then insert the flanges.... so boring...
how do you do so easy things? is there something i missed?
Phil
Phil
