Element.GetParameterValueByName Use
    I'm trying to get the height of walls by Element.GetParameterValueByName
    But it doesn't work
    I tried the same way used for windows (it worked for windows but not walls)
    Photos are in Attachements
    Hello Anasanas,
    I'm not sure what it will be in another language beyond English, but in the English version we use Unconnected Height to give us the height of a wall.
    As showcased below:
    Sol Amour
      I still have the problem maybe i have to load another version of Dynamo than 1.3?
      Originally posted by amoursol View Post
      Hello Anasanas,
      As showcased below:
      Problem still exists, For info I can use the parameters in english without problem. Thank you
        You need to capitalize the parameter name: Unconnected Height, not Unconnected height.
        chad
          The problem is still here, do you think I have to load another version of Dynamo than 1.3? I take the same program as amoursol and it gives me a null list
            As Cellophane mentioned, when you type in Dynamo is is very case sensitive. As per your image, you need to use a capital letter for the word Height. Please fix that first and see if it works.
            Sol Amour
              it did not actually. it is weird
                If you use element.parameters does the value you wish to pull show in the list?
                Julie Kidder
                Architect + BIM Director
                  It looks like you are using a French Revit, so I guess that you need to use "Hauteur non contrainte" for your parameter name instead of just "hauteur" or Unconnected Height. You need to use the exact text that shows up in your properties window, language and the capitals included.
                    I agree with Robin and...
                    i'm french user!
                    But let me suggest you to start writing your code in english...
                    Sent from my SM-N910W8 using Tapatalk
                    Loading...
