How to hide my elevation view name
How to hide my elevation name??
You can edit the tag and remove the lable from it I guess.Company Website: www.deurloobm.nl
there will be a label in the tag to remove
click on your elevation marker and "edit type" and you will see what kind of marker has been used copy this name and then close up the edit type window.
go down to families in your project browser and right click on "families" and enter the name you just copied
It takes you to the marker family, now right click on that and edit.
now you are in the family editor for that marker.
Remove the label "view name" and just leave the circle and the label Inside of that (or edit it as you please)
"Save as" and rename the view marker and keep it in your Library somewhere.
"load into project and close"
In your project again, click on the marker and edit type again.
Now where the marker type is defined in that elevation marker, change it to the new one you just modified.
done.
Good morning Revit Forum,
So I'm working on annotating some sheets and noticed that the elevation tags were not displaying properly. There's...July 23, 2012, 03:34 PM -
Okay, this is driving me insane. I want to use the round interior elevations tag, but I don't want it to display the view name. I can't figure out how...March 1, 2011, 10:13 PM
why do these two look different when they have the same properties?
I want it to look like ElevA (normal)...June 3, 2013, 07:06 PM -
I know you must be tired of hearing this & that the answer is here somewhere in the forum...but I can't find it!!
How do you change...April 8, 2011, 12:49 AM -
I have created a tag and a label and used the following on the paramter
Name = F
Discipline = Structural
Type of Parameter...January 24, 2013, 11:15 AM
