Hi everyone,
I am trying to set the visibility in my views.
What I want to achieve is to show drainage and chilled water pipework at high level with the low level drainage not in the view (i.e. connecting to plumbing items).
When I adjust the view range the low level pipework is turned off (which is what I want to achieve) - however the plumbing items are also invisible (which is not what I want to achieve).
So essentially its a process for making all drainage pipework below (say 2000mm to be invisible) with all other items below this height to be visible.
I'd really appreciate any advice please.
Many thanks
Many thanks
