See my response in the other thread, about family categories. The modeling environments are completely different. Conceptual massing does not use the primitives that generic models do.
Jon
Can you develope your reponse : "Conceptual massing does not use the primitives that generic models do."
Well it kind of does. You can create the same primitive geometry as generic modelling but the creation method differs slightly (create form vs. extrusion button) conceptual massing allows more geometry types such as lofting and pattern based form generation.
I created a generic model family to 'act' as a residential dwelling unit. I created a mass in this family. The family has formulas to create the shape...
When designing floor layouts in plan view I frequently use a mass to quickly tell me the building's gross floor area as the design evolves. Because I'm...
I have created a Conceptual mass with several point heights. The mass will then be duplicated rotated and mirrored several times. I would like to add...
