I'm working with some columns built around Paul's Renaissance Revit stuff and in the project environment the pedestal base is not hiding when changing the family type to Without Pedestal, which is controlled by a yes/no switch. In the family editor it works as intended and if I create a new project it works as intended. Any ideas on what broke?
Visibility Control not working in Project
It was a family parameter so it was only in the family itself. The other functions associated with the parameter worked fine, it was only the visibility. Replacing it with a new y/n parameter made things worse, however creating a copy of the family on the drive (literally copy/paste) and adding the copy to the project seems to have resolved the issue. :banghead:
Take a family, any family. Edit it, add a new SP, say an integer, as a type parameter in the data group, enter a value 1 then load it into a blank project...August 26, 2015, 11:24 PM
I have a question and would like to know if i can do anything without use global parameter.
I work with Revit 2019 (structure).
...June 6, 2019, 10:05 PM -
Okay, this is driving me crazy! I have got a non-shared family TYPE parameter of the LENGTH kind serving absolutely NO purpose (other than to tick me...April 5, 2016, 02:30 AM
When we finish our drawings, depending on the project, we put an electronic stamp on it.
As of now I just have the stamp as an annotation...-
Channel: MEP - General
June 4, 2014, 02:23 PM -
When editing a family, why is it when I flex a parameter that has visibility on or off, I do not see the result?
I have to wait until I have loaded...-
May 3, 2012, 12:02 PM -
