One of my MEP guys brought this up and blew me away. If you setup your pipes to the right system type, demolish it, it then becomes an undefined system. Any good workflows for this so that they can maintain the system type information?
Demolish pipes - lose information
Yeah sucks don't it? We utilize a workset + filter hack/workaround for system elements (ducts, pipes, conduits, and cable trays). Place demo elements on a "Demolition" workset. Apply a filter to the view so that elements on that workset change color and line type in demolition views and turn off in new views.
There is a Revit Idea out there looking to address the issue. Vote early and vote often.John Karben | IMEG Corp.
Demolition is a mess for MEP. I've done the workset thing as well, even though I hated doing it. The idea that we would need to have demolished systems never occurred to Autodesk, it seems. The reason is that Revit was made for architecture, with MEP being an add-on.
It would also be nice if there was a way to get pipe and duct tags to recognize the phase of what they were tagging, so it would place the desired prefix (for new, demo, or existing) before the size automatically. We have Types in our tag families with that bit of text turned on or off, but we still have to manually select it, which is a drag.
Using 2018
I'm trying to do my first project using a workset to do demolition instead of the awful built in phasing. One issue I'm having...-
Channel: MEP - General
July 23, 2018, 04:21 PM -
Hi everyone,
I'm quite new to Revit MEP. Been hanging around the Revit Forum for a while and have gotten some really nice help from previous...-
September 18, 2019, 06:10 AM -
For all the pipe designers out there. Would it be better to create Worksets by Pipe System or by Drafter?
January 26, 2017, 02:19 PM -
Found an odd issue today in a project. There are 9 MEP elements on a built-in Revit workset called "Project Info" (see screenshots). When you...
Channel: Worksharing and Cloud Coordination
June 7, 2012, 08:24 PM -
Way back in 2007 we were told, in training, that Revit MEP 2008 would slow down with 8+ worksets. Was it true then and is it true now?
June 8, 2011, 03:25 PM -
