Beam Cut
    Beam Cut
    I have cut those steel beam slanted as shown in the attached image below.
    the building consist of 3 blocks
    eg.
    1 east block,
    2. west block,
    3. north block.
    all the blocks are worked in separate file, after completing it is combined into a single model
    the problem is after binding the model the cut using reference plane was lost.
    Dhilip Seshan
    +91 8124181665
    www.dhilipseshan.n.nu
    Can you copy paste same place including the ref plane from one model to the other?
      If I use the copy / paste option, the tags , dimensions and other elements will lost.
      Dhilip Seshan
      +91 8124181665
        You will want to create everything in one model. Our office attempted what you are trying to do on a project quite a few years ago and it was nothing but trouble.
        Loading...
