He doesn't need to use render appearance because his visual style is set to realistic.
There could be several issues. There is a small I would call bug. You can try to create new view template (duplicate any and rename) and change all settings. This happened to me previously that Revit was simply not accepting changes to my view template settings so I had to recreate it again. It works 99%.
Other issues can be if you duplicated material instead of creating new one. So if above doesnt work, create new material, with all the properties including images (generic and bump).
You can try to replace material assets in the from appearance tab.
When material is changed no visual change can be identified
Hello everyone,
I have a drywall material and in elevation (shaded) it shows as true white. When I duplicate that EXACT material OR create...April 25, 2017, 01:56 PM -
i do not know what is happening i assigned material site water nothing is appeared of this material in water....December 8, 2011, 02:50 PM
I've searched, but upon skimming the results, didn't really find what I'm looking for. Granted, I didn't look very hard. :laugh:
So,...August 7, 2012, 03:54 PM -
When I change the duplicated material in the material browser the original material also changes it's properties as shown in the pictures below.
...June 6, 2014, 07:43 AM -
I have a project with one material definition that is causing major issues. It's a material that exists in our company template, so I don't know why...August 28, 2018, 04:06 PM
