1) I unfortunately started my project in metric but i need to be in imperial how can i do so??
How to change Revit Metric to imperial when i started project in metric.
Originally posted by rishie View Post1) I unfortunately started my project in metric but i need to be in imperial how can i do so??
Try it, you'll like the resultsI'm retired, if you don't like it, go around!
Originally posted by rishie View PostI searched i could not find a solutionI'm retired, if you don't like it, go around!
Sorry I was not clear in my question,
I know to change my units by accessing project units dialogue box
But even though i changed my units, all my library in property palate named in metric (like Generic 300 mm wall) i want it be in imperial (like Generic 12" wall)
I changed my default path for family template files to English_I (imperial), and even all templates (like construction, structural) to US Imperial and respected imperial templates
All those settings for your families; type names, sizes etc. follows the initial template.
So you have 3 options: 1) start over from a imperial template 2) change all those type names and sizes manually 3) accept that the metric system is better in every way and start to use that instead
Either option is a hassle for you, I know, but that is sadly the situation.
Hello there,
Im a noob in revit and can't understand the dimensions I input in Revit because everything is in imperial and the system...March 23, 2011, 03:11 PM -
I have imported imperial families before into my metric project a few years ago, and I have forgotten exactly what happened. Can they convert automatically...
June 25, 2011, 12:34 PM -
I'm using mep2012 and a sample project is in metric. How do I convert the file to Imperial?
Thanks.-
Channel: MEP - General
May 27, 2011, 07:09 PM -
As I have been trained and schooled in Metric and now having to deal with Imperial on the otherside of the world, I thought I would open this one for...January 11, 2011, 04:18 PM
hi everyone newbie here, I've just started using Revit 2012 and I'm needing to change the properties tools from imperial to metric!
Can someone...July 22, 2012, 09:51 AM
Monumetric Footer In-screen
