What Revit Wants: Getting Better and Faster at Revit – Part 1
    There is a big difference between a Revit user, and someone who has really mastered the software. The more you learn, the faster you get, the more you can learn! In this blog series, we will cover topics like:
    • Productivity Improvement through User interface tips and Keyboard shortcuts
    • View filters and View templates
    • Free addins
    • Some Dynamo
    • And More…
    There are plenty of ways to do things in Revit… but we are looking for the fastest and best way. We want to maximise productivity and quality.
    Targeting ‘Expert’ users so we will move quickly in general.
    A lot of productivity gains come from user interface and shortcuts. Save 2 seconds every time, it all adds up quickly.
    Try to take a few things away with you from this series that will save you time each and every day.
    We will separate our tips and workflows into these major categories:
    • Productivity – faster ways of doing things
    • Workflows – better or alternative ways of doing things
    • Management – ways to better manage the Revit model
    These tips were put together for a recent lab session using Revit 2018, and they are basically in note form along with steps to take in Revit.
    The first post in this series is focused on setting up the Revit UI.
    Workflow Category Revit Item Details
    UI Settings Setting Up Revit UI for Maximum Productivity
    Note:Please open Revit, and open the rac_advanced_sample_project.rvt
    Please download and import the supplied KeyboardShortcuts.xml
    KeyboardShortcuts
    Productivity Double-click In Revit Options, change default for Family to Edit Type:
    Try double-clicking on a Door now.
    Productivity Double-click Double clicking a Wall will automatically start the Edit Profile command
    Productivity UI – QAT Showing below the ribbon will allow you to add more tools.
    Do this now.
    Certain Revit tools should always live on the QAT. Add them now:
    • The Revit built in auto section box tool (since 2016)
    • Save and Load Selection
    • Set and Show Workplane – for quick 3D modelling
    • Manage Links
    • Dynamo
    • Dynamo Player
    Productivity UI – QAT If you have a reasonable size screen, you could add somewhere around 20 buttons to the Quick Access Toolbar.
    Some other easy productivity gains:
    • Align (but should really be a keyboard shortcut)
    • External Tools – NWC Export
    • Revitlookup,
    My main workstation (2016):
    Productivity UI – QAT Type Selector can be added to QAT:Workset Chooser can also be added to QAT:
    Productivity UI – Ribbon RibbonRe arranging ribbon menus…
    Hold down Ctrl and set it up like this:
    Panels:
    • Undocking
    • Possible to set up tool palette on other monitor?
    • Re-docking back in place
    Management Content Locations Changing the home of your Revit content with NotePad++ and revit.ini
    Management Places List in Open / Save Dialog You need to find the PlacesOrderxDisplay value for a given entry…In this Registry key:
    [HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 2016\Profiles\AllAnavDialogs]
    Easiest way is to export that AllAnavDialogs to .reg file, edit in Notepad, then Merge back.
    Effect will be immediate in Revit.
    Link
    Note:
    Please close and re-open Revit to commit the changes to UI (in case of a crash later)
    Open the rac_advanced_sample_project.rvt
    Navigate to 01 – Entry Level – Furniture Layout
    Place some Furniture in the Lounge
    UI Shortcuts
    Productivity UI Right-click- Repeat
    Right-click- Recent Commands !
    Recent commands will also help ‘teach’ you the Keyboard Shortcuts:
    Productivity UI Right-click Create SimilarI use this a lot – you usually have a similar object floating around and it makes sense to start the creation tool directly from that element
    Productivity UI Right click to get to Properties and Browsers – You can turn System and Project Browsers on and off quickly
    • Try turning PB and Properties on and off with right-click
    • Even inside the PB, you can switch Properties on and off
    • Good for minimal screen real estate
    The post Getting Better and Faster at Revit – Part 1 appeared first on What Revit Wants.
    Author of What Revit Wants
