Door family parameters
    I am working on a model (given to us from another firm...long story) that has door families in it. I would like to find a way to export the parameters from their door families into our new doors. It appears that there may have been a shared parameter file, when the model was at the other firm. We do not have the shared parameter file now, nor do we have access to it.
    Is there a way to export the parameters from a door family and import them into a new door family?
    As always, thanks in advance...
    Yes you can export shared parameters.
      How...and can you do it if you do not have the shared parameter file in hand?
        I think you have to do them individually or maybe use Dynamo.
        Revit OpEd: Export a Shared Parameter
        Chris Ellersick
          Yup I've done them individually. It was from that exercise that I learned the proper way to do shared parameters.
            Yeah, you do them individually, one by one, into the same txt file and eventually you've recreated the original shared parameter file and all the original parameters' GUIDs are there.
            Kamran Mirza
              Worked like a charm
              That little Revit tutorial worked like a charm.
              Thanks :beer:
