I'm creating a dynamo script where you input the Length and Width of the simple building and it draws your grids, and tiltup walls based on the parameters you put in, this part works great. The walls are drawn by using Point.ByCoordinates for the start and end points, then a Line.ByStartPointEndPoint is created connecting the two, and finally a wall is generated using Wall.ByCurveAndHeight.
I'd like to host a door in each wall panel, but for some reason, any attempt i do to place the family instance fails..
Does anyone have any guidance on placing a door/window family in a wall?
I've tried using to learn from this dynamo script:
Topic: How to put a door or window object on the wall ? | Dynamo BIM
but all it does is run through the task, return no errors, but not actually place any objects.
