I create Autodesk Revit packages, and have them distributed by SCCM via Task Sequences. When you select Task Sequences for Revit 2015, 2016 and 2017, the second and third option fails. Does anyone happen to know whether one needs to reboot the computer, after installing a version of Revit before installing another version?
Don't know if this is a new issue, or simply it has always been this way....
Baffled... at why there are so many SCCM Task Sequence failures with the Revit Task Sequences all of a sudden....
