Hi guys i have created the above column using structural column tamplete but i am unable to create analytical column of of similar geometry the analytical that come along with this is a straight vertical line, please help i have intermediate knowledge of revit
How to make analytical model of specialized column
Hi guys i have created the above column using structural column tamplete but i am unable to create analytical column of of similar geometry the analytical that come along with this is a straight vertical line, please help i have intermediate knowledge of revitTags: None
It isn't that hard to determine the analytical lines x,z of this. Sorry if being straightforward here.. Are you a student? What (3d?) software are you using to do structural tasks? I noticed some funny looking k/s on the right (...?? Wondering why you think it is 'Revit question' to be solved)Last edited by HansLammerts; May 22, 2017, 09:45 PM.
Originally posted by HansLammerts View PostIt isn't that hard to determine the analytical lines x,z of this. Sorry if being straightforward here.. Are you a student? What (3d?) software are you using to do structural tasks? I noticed some funny looking k/s on the right (...?? Wondering why you think it is 'Revit question' to be solved)
I don't think in ONE column the analytical lines can split into two branches. Is it modelled as one piece? My advice would be to consider two seperate models, one for arch, one for Robot use with simplified element, and correct analytical lines. Its hard to have them both in onebim.Last edited by HansLammerts; May 23, 2017, 06:34 AM.
how do I adjust my pillar fork, with the analytical model?
I wish that the analytical model would fit to the two arms of the fork!...-
November 2, 2013, 02:19 PM -
Hi everyone. I have a problem with my structural column analytical model.
When I create a steel structural column the bottom node of analytical...-
October 29, 2013, 10:14 AM -
As attached, there are some vertical lines in blue color ( is it analytical model? )despite the fact that I have joined...-
September 7, 2011, 04:22 AM -
hello guys, I just have one question ....
Once I created the family of Pillar, from template "Structural Column Metric" how do I change...-
Channel: Structure - Family Creation
April 7, 2015, 01:50 PM -
I've got a question regarding a parametric family (structural framing).
I created parametric family of a frame with trapezoidal...-
October 5, 2018, 11:08 AM -
