I'm trying to create a sequence of tiltup panels with a 2" gap between them. I've created a list of start and end points for each, then created a Line.ByStartandPointEndPoint. But when I do Wall.ByCurveAndHeight, the ends of the walls join together. There are distinct walls, but it looks continuous. Is there any way to force the Disallow Join and break the wall panels?
Disallow Joins in Walls?
Just an idea...could you create your wall runs from a single curve then use 'split with gap' at set distances along the curve?
Haven't discovered how to disallow joins with dynamo yet (havent needed to) but there are plenty of addins around that will do it.
Edit :heres a working (apparently ) phython script if you're into that Topic: Disallow join of the wall | Dynamo BIMLast edited by elton williams; May 21, 2017, 10:11 PM.There are no stupid questions, only stupid people
Hello Ryan,
The following script will give you what you desire (Disallow join at both ends) from each of the selected walls.
It has been annotated to showcase what is going on! Hopefully this is of use to you.Last edited by amoursol; May 23, 2017, 02:13 PM.
Sol Amour
for what it's worth - there is an addin on the exchange that will let you disallow joins on a selection of walls: https://apps.autodesk.com/RVT/en/Det...en&os=Win32_64
If you are creating your walls through dynamo I doubt it will do much for you but thought I would at least mention it.
That script is awesome Sol. It does just want i need. I think one thing that people should be aware of is that there needs to be more than one wall be passed into that node. I was testing it with just one wall, and it failed, but as soon as i put in two, it worked great.Ryan Taube
BIM Manager - Clayco Construction | Lamar Johnson Collaborative
Oops... I can add one other section in that will allow it toI obviously didn't test it enough!
Sol Amour
one curious thing i've come across while doing this, is that even with the script, revit will still push the ends together the first time it runs through, then i run it with a 24" gap, then back to 1/2" gap and it behaves fine. The ends are still disallowed, regardless, thanks to the script, but it's curious behavior at the start.
edit: attached is that portion of the script and the plan views showing the behaviorAttached FilesLast edited by ryntau; May 25, 2017, 09:19 PM.Ryan Taube
Originally posted by ryntau View Postone curious thing i've come across while doing this, is that even with the script, revit will still push the ends together the first time it runs through, then i run it with a 24" gap, then back to 1/2" gap and it behaves fine. The ends are still disallowed, regardless, thanks to the script, but it's curious behavior at the start.
Sol Amour
i need the red panels to wrap around the corner
also if anyone can help me with my hot mess awnings that would be great...
July 22, 2017, 01:50 AM -
I have a wall that is joined to 5 other walls, and despite unjoining the wall from everything or cutting and re-pasting the wall it is still joined to...December 9, 2011, 05:58 PM
I mean, I want to join the two walls and get that blacked triangle done.(without moving the walls axis)
https://i.imgur.com/aXfYGTw.jpgApril 17, 2020, 05:03 PM -
Hi there,
I have got 2 different walls thicknesses. When I look at the 3D view, I can see those walls separated.
I have tried to use Join...October 17, 2019, 11:21 AM -
I have had some odd issues with walls in 2012.
It seems like they are more 'attractive' to each other than they were in 2011. specifically...April 26, 2011, 04:32 PM
