An explanation of the Revit project location elements and selecting the right one to use.I see two project location elements: 'Internal 21748' and 'Project 111428'.The active Project Location is 'Internal 21748'.However, the values in 'Project 111428' are correct and can be used to transform the coordinates, whereas the values in 'Internal 21748' are nonsense.Why is the active project location wrong?How can I determine which of the two to use?What is the difference between these two? ...
