Hi all,
Here is my issue: Created my house in the elevation 00. After the design is done we got the survey in dwg. I linked it into Revit and created the topo in the same file as the house by using points. (00 = 235.0)
Result: My topo (sea level) is off set from my house.
I tried everything possible and could not find a solution. If I relocate the project the whole thing moves up.
Moving the topo down doesn't help because we need to be able to edit the topo with the sea level coordinates.
Question: How can I manage to have topo and project at sea level and still show the project base point for levels in sections?
Any help? Thanks!!!
Any help? Thanks!!!
