formulas in revit
    formulas in revit
    Hi all,
    I need a bit of help with a formula in Revit,
    it is
    if x is on but y is off then turn on z
    what I have so far
    if ( or (Transom = not , Mullion = not) , <False> , <True>)
    Please help its the last formula to complete the window
    Thanks
    <false> should be a false statement: 1=2
    <true> should be a true statement: 1=1
    chad
      thanks I will give that a go
        and(X, not(Y))
          Thanks for your help I'm still missing something though, it works if I'm asking if the transom is on "if(Transom, 1=2,1=1)" but as soon as I try to ask if the mullion is off it wont do it.
          attached is a screen shot showing the formula and the error message. would be gratefully for any more help.
          I am using Revit 14 if that makes and difference.
            I think, you only need:
            And(Transom, not(Mullion))
            "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
            unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
            Lewis Carroll
              you are missing a comma before the <false> statement. not(Mullion), 1=2
              however I think the And Not statement Andrew & duende mentioned will be a little easier in the long run.
              chad
                Yes/no parameters are inherently true/false, so I'm not sure why you'd ever need to use the 1=2 statements. There might be a case I'm not thinking of, but I've never had to use that extra step in any of my formulas over the years. I think they're just mentioned in the other thread as a way to lock a parameter in a family. Duende's formula should work.
                  This sort of operation is to limit the choice.
                  It says if this one is turned on, then the others must be off.
                  It is an "if-then" statement technically. if this condition is met, then do X (ie turn off)
                  I can also do an "if-then-else" statement.
                  if I just use yes/no parameters, I actually have to check or uncheck the box to turn it on/off.
                  if I put a conditional statement, my choice elsewhere will drive the decision and it removes the check box for the choice
                    The if/then statements or and/or make sense and I use them all the time. I was talking about using 1=1 or 1=2 to force the yes/no condition. That seems like an extra step that is already accommodated by the formula logic.
