is there a way to change a parameter in Multiple schedules at the same time ?
schedule parameters
I think you'll need to define what you mean by 'change' and what type of parameter you are talking about. It's easy to modify the instance vs type setting, or the name of a Project parameter across many schedules at once, assuming you are using the same parameter. Other changes, such as changing the format from Text to Length, will not be possible without removing the parameter, which would then need to be added back to each schedule where it is used. If you are talking about a Shared Parameter then it gets a bit more difficult.Glynnis Patterson, Architect
www.ideatesoftware.com
I have been racking my brain to come up with a method to bring in all the finishes in a project into one schedule and sort them by type of finish (floor,...
September 21, 2017, 07:21 PM -
Hi there,
2 questions, if you could explain me?:
1.When I use a shared parameter in elements I can extract dimensions into the...September 23, 2021, 04:22 PM -
hello,
I have a yes/no type parameter in a family title block.
I create a share parameter and associate it in this parameter.
This...April 21, 2017, 02:52 PM -
Hi Guys
I have an instance parameter in a pile family that shows the pile cut off level. The Parameter is a text parameter. I have loaded...September 11, 2013, 02:24 PM -
So, in this thread I encountered an intruiging option with schedules that I never noticed before.
After some testing this option blew my mind:...-
Channel: Tutorials, Tips & Tricks
July 22, 2011, 08:29 AM -
