The joys of upgrading
    2017 has brought some very welcome enhancements to the table - however I've been noting a few niggles, and thought I'd share them here to see if others have also noted these - and (more hopefully) found 'fixes'.
    1. We appear to have a whole host of random dimension styles - most all named the same (!?) unused, and un-purgeable.
    2. We are noting (some) children families are not displaying as they once did (in 2015). Be that in the file they're placed, or through links (using raw/vanilla VG - this isn't one of the "33 things"). As per the attached screenshots, the elements are there - but "not". In the example, the "operation lines" are model, but it's not just lines, the (grand)children families of my hardware aren't showing either. Has the behaviour of symbolic/model lines (in families), or handling of nested families, been overhauled between releases? Frustratingly, it's inconsistently (un)reproducible - I've just started a new model (that uses the same upgraded-from-2015 content) and that's happy to show them. :banghead:
    3. There appear to be a whole new host of MEP Fabrication categories I now need to go catch in all of our VTs - which is always fun (why can't the default behaviour be to not add!?) - is there a list of (all of) these little changes somewhere so I can hunt them all down in one go rather than trip up on them as and when?
    It would appear I'm not alone with the first one...
    https://forums.autodesk.com/t5/revit...l/td-p/5522068
      And a new one just emailed to me by a team member...
      utterly random line pattern styles creating themselves - and dirtying my name. :banghead:
        This just keeps getting more fun.
        Detail Item Schedule, no filter/sort tricks - and I've 9No. rows without any information.
        Deleting the rows raises the "this will delete" warning - not that helps explain what I'm about to delete.
        :crazy:
          Yuck.. If you add the count field does is it empty too?
          That he is mad, ’tis true. Tis true, ’tis pity,
          And pity ’tis ’tis true
            Frustratingly no, the count counts - and the only field with anything in it.
              Wait, have they broken drag 'n drop (from Browser, of Details items) whilst in group edit mode as well?
                Have you got Ideate Explorer? Just checked and i've the same in my files (181 of them :banghead.
                They are masking regions!
                  Nope.
                  Seriously? What a joke.
                  I'm thinking I'm going to bundle all these into one support ticket.
                    But for now I'm going to keep throwing them all into here, so to revisit last week's find:
                    No checkboxes at the family level of the Purge dialog:
