Architect Model is Green
    Currently working in Revit MEP and have linked in the Architects Model. The model is the colour green throughout - in 3d views, sections and elevations. How do i 'select all' the model and override lt as grey without having to go into each individual view template and custom edit.
    Ive opened up the Architect model alone and its green there also.
    Regards
    Andy
    not sure if this will work but you could try opening your manage/object styles and changing the default line color for all of the architectural elements (use the filter list at the top to change them only for archi elements) to be black.
    if that doesn't work, your only option might be to update your view templates to modify this within the vg/rvt link tab for every view template you have to achieve a wide-scale effect.
      If what Darryl suggested doesn't work then you could try what Architects do with MEP models and use filters to override the graphics and add that to your view templates.
