Hey, you team of brilliant minds!
I need some thoughts, please, of the best method to go about modeling the extension arm of this wall fixture (attached). I've shown here the other segments I've already modeled, but my experimenting is not producing results for the arm section that holds the lamp out.
I've tried and failed creating curly cue Revolves along that path. I made a blocky Extrusion that follows that path, but can't get a void sweep to work correctly along those curvy paths. Should I try to mass it and then pull it into the family somehow?? And how would you handle the ornamented leafwork??
Thanks for all your ideas! I'm stuck and really appreciate it.
Sincerely,
Aaron
Sincerely,
Aaron
