Is it possible to quickly copy/create room schedules from one finalized schedule template?
For example;
A room schedule showing furniture content, once all fields applied & filtered by room number - what is the quickest way to repeat this process for all rooms in the project? I am trying to streamline this time consuming process and avoid manual schedule creation & renaming. Currently projects in Revit '15 & '16.
Has anyone a dynamo script or any add in suggestions to automate the process?
Ideally the automation would re-filter & rename each schedule using room number.
For example;
