Hello I am creating two dormers. For some reason the results I am getting are very different.
In the left one I have already used dormer opening tool. In the right I have yet to do this.
However, problem is that while on the right the window I drop in cuts a hole so that it is properly hosted but on the left the hole is not cut. I get error message:
Can’t cut instance of 610 x 1220mm window out of wall.
I thought I wouldonly get this error message if I was dropping window into a void or something like a door but clearly this is not the case.
If you look at image you can see: a window embedded in a wall without cutting an opening!!????
What is going wrong?
