We use the 'insert views from file' command to bring our standard details into a project. However, the inserted views don't seem to bring the applied view template in with them. Is there any way for this to happen?
Insert views from File doesn't bring View Template over
Originally posted by evan.dodds View PostWe use the 'insert views from file' command to bring our standard details into a project. However, the inserted views don't seem to bring the applied view template in with them. Is there any way for this to happen?
Make sure to have both projects open.
FWIW, transferring over View Templates can get "interesting," depending on what the VT overrides. For instance, if you TPS in the View Templates, but dont bring the Filters, and Filters exist in that VT that dont exist in the new Project, it doesnt something weird. I dont remember if it fails to bring it over, or if it just drops the Filter, but im certain it doesnt automatically bring the Filter over, which is a PITA.
Similarly, it cant bring over settings on Linked DWG or Linked RVT files, as they all have unique GUID's for the Links, and it *drops those* when it comes across.
Just a few more things to think about with VT's and transferring.
Think of this scenario - you have 5 different Revit projects all linked together in various ways. You want to ensure that there is some consistency in...
Channel: Blog Feeds
May 27, 2012, 11:45 PM -
Hello!
I have transfered a view template for the file that i'm working, but when I apply this on the view this does't show as i want.
I checked...June 18, 2015, 06:27 AM -
It is now possible to create new view types for all views except for area plans and sheet. This means you can create your own versions of floor plans...
Channel: Blog Feeds
May 15, 2012, 09:15 PM -
is there a way to do this with Revit 2017January 31, 2017, 06:59 PM
Hello all! I'm wondering how I can apply a V/G override to more than one View? What I'm doing is in my Floor Plan Views, I'm going to the V/G and setting...January 18, 2012, 02:53 PM
