Hello,
simple question and so far not found an answer for it:
if you export a plan view to cad, using shared coordinates, the result will nicely line itself up with survey plan (which has served you to place your project). If you export the same plan view sitting on a sheet, you'll only have the base point, it seems like you are loosing the shared coordinates (even though you chose to export respecting thel).
Well, there isn't a way of having both ? Shared coordinates and sheet ? I found my workaround in CAD, but it's too much time !!! maybe there is a plugin ?
Thanks in advance for your advice
Kunster
Kunster
