Fabrication Parts - Connector Change
    Does anyone know if there is an easy way to change duct connectors in fabrication parts?
    Thanks,
    The best way to have the right connector from the start is to edit the service specifications in a fabrication product (CAMduct, ESTmep, CADmep). Other than that there is no quick way to change a connector inside of Revit. You have to open the 'Edit Part' window every time.
    Hmmmm... You've got me thinking that it's possible to change the connector with an instance parameter in Properties window with the help of Dynamo. Let's see how far I get...
    Loading...
