Good day everyone, curious how you guys hide main categories, but show subcategories.
I usually have a workset called SLEEVES so I can do sleeve drawings while hiding all other mechanical stuff.
But this time I'm minimizing the number of worksets because I have a ton of them - one for each level, one for each link.
So I created a sleeve family as a subcategory of Pipe Accessories.
Problem is, I want the subcategory SLEEVES to show, but I don't want valves.
I also don't want to modify every valve I bring in under it's own subcategory VALVES.
Would like some help here. Sounds like I'd better stick with a separate SLEEVES workset.
