I my name is Cristian Tolava and i have a huge problem. How can i redound the parameters that i calculate while doing my schedules, i know that in the window of format you can put limits of how many decimals you want to see, however the fact of putting 2 decimals for example does not redound de number. To be more clear when you are using excel you can use de comand redound and for next operations excel just use two decimals insted of all decimals, is it posible to do that in revit.
I will be very thankful for your help
