I am basically starting the Revit division at my work. Right now I am creating a template so when other people send us designs I can link it to our template. I have already imported tags and title blocks. My question is about views, at first I was thinking I would create 10 floors of views, that way if we do a multi floor project the views will already be there. But that wouldnt work if the floors are different heights. Is there a way to copy the view from a linked revit file? Should I create pre existing views on our template? Whats the best way to do this?
Revit Template for work
We started out with only 2 floors in our Template, assuming people coulld "just" add floors if they needed them.
Then we issued a project (yes, Issued) that had a lot of Sheets with a THRID Floor. Never got caught in QA.
So after that, we bumped it up to 5 floors plus a Lower Level.
Since our typical project has several floors, each of which may have 2 or three Zone, and each of those having up to a dozen different Sheet Types (Existing, Demo, Floor Plan, Equipment, Furniture, Presentation, RCP, etc) they add up fast.
It's a lot easier to delete Views and Sheets than it is to add them.
And that way they already can have View Templates associated.
As far as the actual Elevations of the Levels, that's a piece of cake to Link in the consultant's model, go into an Exterior Elevation and adjust your Level's Elevations to match theirs.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by DaveP View PostIt's a lot easier to delete Views and Sheets than it is to add them.Greg McDowell Jr
about.me/GMcDowellJr
Originally posted by GMcDowellJr View PostThis has been my working assumption as well... but I'm thinking of leveraging Dynamo to manage all of this. No reason we can't get D to generate all the various views with view templates on demand (at least I don't think there is).
But, i dont have the Dynamo skills (yet) to get it to do everything thats set up for every level in my template. Its a LOT of views, and Sheets, and Schedules, and placing things PRECISELY on the sheets, and on and on. But i would love to get there.
One of my clients has a 12 level version of my template, but they do some much taller work. They have loved the benefits of it, and are asking about adding another 20 levels in to the template. I would much rather send them a graph that does it, but it would have to work extraordinarily well.
I've got a couple things to work out. In addition to creating the views, which I think should be easy enough, I also have a need to change titleblock size. Nearly everything I've done in the past 10 years has been 30x42. This firm does a lot of 24x36 and a fair amount of 36x48. My plan is to setup the sheets for each, record/export the viewport locations, and use these values to recreate the sheet with Dynamo. Instead of having any sheets in the template, the user will select sheet size, number of levels above/below, which internal scope boxes to use for enlarged views, and the graph will take over. That's the plan anyway.Greg McDowell Jr
creating project template on the fly is my to-do-list for quite some time but not actually being implemented yet, too many variables and extensive UIs are needed if including all factors, Dynamo may have limitation (at least on UI side) but API sure can achieve most if not all, no such utility tool yet in App store or elsewhere?
Ehhhh. If im being an arrogant ***** about it, i would say: No tool exists, because just about every person out there builds templates differently, and what is a *good and complete template* is open to interpretation. I saw someone on twitter bragging about an app that *BUILDS REVIT TEMPLATES FROM EXCEL* on twitter the other day. And im sure it actually works really well, but no offense to the creator: All it does it manage some of the object styles, or specific settings in a template, like Text or DIM Styles. It doesnt come anywhere NEAR the level of complete that i would consider "real."
But, certainly every person who makes a template COULD write down all the things that exist on "a hypothetical LEVEL 2" of a project, and then someone could go from there to make a Dynamo Graph. (I say L2 because L1 always has all the special stuff from the template connected to it...)
What is is I have a template with all my views set up. (for documentation purposes) ie
M57-vent -
00-vent
01-vent
02-vent...-
Channel: MEP - General
June 12, 2013, 11:09 PM -
Some of our projects work best with 24x36 sheets. Some work better with 30x42. We have some standard detail sheets we use in all projects but the use...May 15, 2013, 05:48 PM
Ladies & Gentlemen,
I have set up our project template to include view templates for modeling and for annotation where the modeling views...January 13, 2017, 09:33 PM -
I apologize for the double post! I had initially posted on Aaron's massive template post over under Tips and Tricks, but it got left behind at the bottom...May 23, 2016, 04:45 PM
I was curious to see how long a typical project setup takes you. Small, medium and large jobs. What do you do to speed up the process? Do you utilize...
July 29, 2014, 10:08 PM -
